Eric Jacob
Posted on - 04/06/2012
I have a folder named 6d77d89d35c0b6ad1b719b858fda on my hard drive. Â I have no idea how it got there, and I don't recognize any of the files in the folder. Â I tried deleting it but I got an error saying, you do not have permission to access this folder. Â Any idea on what this is? Â How can I get rid of it? Â Is it possible that it is a virus?Â
Cannot delete a folder in my hard drive
Dear thanks for your question. The folder 6d77d89d35c0b6ad1b719b858fda is system folders so you can’t delete this file and don’t worry this not a virus or other harmful file. If you don’t want to see the file then follows the process giver below:
Open MY COMPUTER-click on TOOLS –click on FOLDER OPTION -click on VIEW-after this click on DON’T SHOW HIDDEN FILES AND CLICK OK
AFTER THIS SELECT THE FILE WHICH YOU DON’T WANT TO SEE –RIGHT CLICK ON MOUSE –CLICK ON PROPERTIES ON POP UP MENU – CLICK ON HIDDEN AND CLICK OK
