Cannot embed or link any audio file to a Powerpoint
I cannot either embed or link any audio file to a PowerPoint presentation. Do you know why?
Please help.
Thank you.
Please help.
Thank you.
For adding sound in your PowerPoint presentation you have to follow the steps.
Note : To add multiple sounds, repeat this process for each slide that contains sound files that you want to add.
May be you are just not using the right procedure to insert the audio files and that is why you are not able to embed them to Ms PowerPoint. Or if you have tried and failed, it would have been better if you could have posted the error message that you are getting when you try to.
You first need to make sure that you have saved your audio file in the mp3 format, and then use the procedure below to embed it:
It is that simple, you will have successfully embedded your audio file in Ms PowerPoint.
Thompson Locker
Notifications
