While trying to extract my bpm file to Word or PDF, I receive the following error message:” Object reference not set to an instance of an object"
And while publishing to web, I also receive the following error message.
"The 'Insert' start tag on line 3 does not match the end tag of 'LI'. Line 3, position 1170"
When I started using the Table extended attribute, these errors began to happen.
I am using the Version 1.6.1 of the modeler. Can these errors be fixed?
arif.bcl
Cannot extract bmp file to word or PDF
Hello
This is a sample problem. If your BMP Image can not open word, you work to do:
1. At fast open your word document and click insert menu.
2. Then Click Picture.
3. Then Click from file.
4. select the file & insert.
Thanks
Mr. Arif
Hi there user:
Upon testing it to my own computer, no error occurred.
Anyway, try to send the bpm file to Microsoft Excel first. And then right-click and send it to Microsoft Excel. You get my point? Don’t send it straight to Word or PDF. From Microsoft Excel, copy the bpm file, and then paste is to Microsoft Word. See if the error still there.
Thanks for asking. If the problem still persists, don’t hesitate to post again here at techyv.com.
Best regards,
Sometimes, BMP cannot be converted directly because of a faulty encryption method. I suggest you use a software called “Mini Scan to Word OCR Converter v3.2”. It is a trial version. If you want to purchase it, you can do so here: http://www.minipdf.com/scan-to-word-ocr.htm
It’s very easy to use. Go to Add image file, then choose output file, then convert.
That’s it. I hope this helps.
