Corin Ronie
10 points
Posted on - 07/08/2014
I created a PDF file in Adobe Acrobat 11 and it was password protected for editing. If I open this file from Adobe Reader on my computer, I can fill in the form to enter the password. If I open it on my iPhone, I cannot seem to fill out the form. How do I fix this?
Cannot fill out password form on iPhone
Hi Corin, if you want to fill out form on an Adobe document using an Android phone, try to check this site PDF. There are lots of PDF fill and sign software for Android devices, and you can also attach pictures, mail it or share it through various social media as well as email service providers. Works across the different platforms for Chrome, Firefox or Internet Explorer. You can also work offline too and later send it via the internet.Â
That problem can happen if you don’t have Adobe Reader on your phone. Before you can open a PDF file, you need to have Adobe Reader installed on your computer. If you need to open the PDF file on your phone, you need to install Adobe Reader on your phone. You won’t be able to open the file if there is no application associated with it.
If you need to open the file on an iPhone, you need to install Adobe Acrobat Reader for PDF on your phone. This app is free to download. It requires iOS 11.2 and higher. It supports iPhone, iPad, and iPod touch. Alternatively, you can download and use Foxit PDF Reader Mobile. This is also a free application for iOS devices.
It requires iOS 8.0 and higher. It supports iPhone, iPad, and iPod touch.
