anonymous
7060 points
Posted on - 08/06/2011
I am using a broadband line on my computer. First time that was not a problem.
But now it is causing many problems.
When I start my computer; then i double click my Mozilla Firefox icon, sometimes it opens and sometimes it does not find any network connect.
So what can I do?
Cannot find any internet line in my system
Good day Khaled_Mithun,
This is your question, "IÂ am use broadband line of my computer. First time that was not problem. But now it is show many problem. when i start my computer then i double click my Mozilla Firefox icon. some time it was open and some time it was not found any network connect".
So what can i do? The answers to your question depend on the symptoms.
Possible problem maybe Internet Connection issue. Â This needs to be verified and you should contact your Internet Service Provider.
Internet networking issue, you may be using wireless connection that loses signal. You need to re-connect to your SSID.
Browser Settings, perhaps you're using a Proxy server settings, often a mistake. You need to check Tools, Internet Options, Connection Tab, and Local Area Network (LAN) and make sure that, use a proxy settings is not checked.
For further questions, feel free to contact us.
Michael
