I cannot find the Bluetooth sign in my laptop pc. I can see the Bluetooth on in the task manager but the icon is not visible in the taskbar. So I cannot not use some functions related to Bluetooth that I have been using including connecting with my phone. Should someone know what to do please notify me.
Frank Marlow
Cannot find the bluetooth in laptop
Having a Bluetooth feature in your system is a cool and great feature but it could be such a hassle if you are not able to access it easily. If you do not see the Bluetooth icon on your system tray, you may do the following steps to access it easily without having to go through task manager:
Go to Start
Then click on Control Panel
From there, please choose Bluetooth Devices
Then click on the Options tab
In the notification are, please select Show the Bluetooth icon
Then click Ok
You will then see the Bluetooth icon on your system tray.
