Cannot find directories – auto removal failed manual removal
I cannot remove few files simply by remove options in my pc and for which I need to remove them manually to free some space. I tried to uninstall it, but it shows an error message.
Now I cannot find the file in the directory either.
So please someone kindly suggest me how to solve this problem.
Arnel Bui
Error:
ObjectGrid uninstallation error
The un-installation of ObjectGrid failed. Cancel this un-installer,manually remove ObjectGrid,and then start this uninstaller again. If you continue with the uninstallation,WebSphere Application Server might not uninstall successfully.
See the un installation log (C:Program FilesIBMWBE621WASlogsobjectgriduninstalllog.txt)for further details.
