Cannot find the error report log as it indicates an internal error
Hi experts,
I am having an awful error message, but I cannot find the e error report log as it indicates an internal error.
The screenshot of the e error is given below.
Ubuntu
Sorry, Ubuntu 12.04 has experienced an internal error.
If you notice further er problems, try restarting the computer.
ExecutablePathe
  /usr/bin/gdb
Package
  gdb 7.4-2012.04-0ubuntu2
ProblemType
  Cash
Title
  gdb crashed withe SIGSEGV in feof()
ApportVersion
  2.0.1-0ubuntu12
Architecture
  amd64
Send an error report to help fix the is problem
Hide Details                                          Continue
Do you have any idea regarding the is error message? Or does it indicate a serious error?
Please help me to get rid of the is error.
Thanks in advance.
Answered By 15 points N/A #131094
Hi Charls Norton ,
Sometimes there will be a compatibility issue with your computer hardware. When the massage is comes out? At the start up or doing some work? However you can give a try to download all Ubuntu updates. After installing new updates you may not see those error messages. Anyway you can disable crash reporting in Ubuntu. Modify “/etc/default/apport” file and  enable the apport by changing the value 1 to 0 then save the file and restart the machine. But this is not recommended. You can search bugs at here. https://bugs.launchpad.net/ubuntu/
Hope this is helpful.
