Cannot find graphics card information
Hello Friends,
I was trying to add my new graphic card. When I try to install it says cannot find graphics card information.
I can listen the windows starting but with no. Can anyone help in this regard?
Thank you for all help.
Error
Can not find graphics card information.
Answered By 0 points N/A #131165
Hello Mr. Joelabrame.
Which processor are you using? It would have been easy to give answer if you gave us some more information. May be the problem is in your database. Have you installed any 'smart doctor' software? If you have installed, please uninstall it now. Clean your computer with Ccleaner. Then reboot your device while starting it. Now install your new driver. This may solve your problem.
Thank you for your question.
