When I want to open the workstation set up on my OSX server, I get an error.
Also, I get an error message when I try to open the Student Network Sign on my OSX workstation or Network Control Panel.
What should I do now? Please help.
Thanks a lot.
Cannot find SNS.bap or NCP.bap
As of now, since you didn’t mention any error message that you encountered from opening your work station I can provide you only basic solution that you can use to resolve your issue. Things that I can only suggest to you are, to restart or reset your workstation. There are lots of error issues regarding with server/ work station. About your work station set up, just make sure that the set up file is compatible to your computer system, and make sure that it is not corrupted. It much better also if you check how to install software that you want to install so that you will not encounter any error.
Hope this helps.
