Cannot find some visual express 2011 tools
I had installed Visual Studio 2012 on my computer for some programming purposes.
But I cannot find several Visual Express 2011 tools on it.
Please help me to how can I fix it?
Hello Lynn,
The latest version of Visual Studio before 2012 was 2010.
Tools are specific to the version you have (Express, Professional, Ultimate, etc.).
You can find many tools and extensions for your Microsoft Visual Studio 2012 from the official gallery for Visual Studio from Microsoft at the link:
Hope that you will find the tools you need.
P Vhilary
Hi Lynn Sinky,
I want to say that you can try to the following procedure to fix your error:-
First of all you have to update your Visual Studio.
Once you can update your Visual Studio 2012 and also check that your OS support to Visual Studio 2012 or not.Â
Then you can fix it.
I hope that you can fix it by trying this procedure.
Thanks & Regards
Gillam Janetj
