Cannot find sound player in app menu.
I am trying to add the "sound player"onto my home screen as a shortcut, but I can't find it in the application menu. I know I didn't delete it because I see it under the applications installed section of the phone. How do I create that shortcut again?
Also, what's the difference between in music player and sound player?
Best Answer by Smoker
Answered By 0 points N/A #113790
Hi Kmithun 094 ,
  • It's easy to resolve this problem please follow my instructions carefully.
  • First of all there is no difference between music player and sound player you maybe want to know what is the difference between music player and sound player (if you mean the pilot of  the sound).
  • What you have to do is go to your music player folder always INC /program files then you have to find the execute file.
  • Right mouse button click and select create shortcut the left click and then the shortcut created what you have to do is just replace it where you want and your problem is resolved.
Answered By 5 points N/A #113792
To create a shortcut on your desktop you can do these steps and you will be able to use the shortcut.
  • First go to START and then to SEARCH.
  • Now select all files and folders
  • Enter the name of sound player you want to search.
  • In look in choosing your hard drive location as your drives.
  • Press search and it will start searching the file.
  • Once you find the file you are looking for right click on it and choose copy.
  • Now go to your desktop and right click on it.
  • After this click on PASTE SHORTCUT it will now show your desired icon on the screen.
As i have shown here also a music player only plays the files that relate to it and the sound player plays such files for which it is designed for. The file format for both players are different which makes them unique.
