Cannot format any partition using the Gparted tool
I get this annoying error message when I try to format any partition using the Gparted tool to fix the problem that cause an MSDOS partition table. How can I remove this error “Invalid partition table – recursive partition on /dev/sdb”.
Guide me to fix this issue. Any help would be appreciated. Thanks.
Libparted Bug Found!
Invalid partition table – recursive partition on /dev/sdb.
