Cannot insert the value Null into column
Hi there,
I have installed Kaspersky Security on my Windows Server 2012 and in Event Properties I found this error and also my antivirus is crashing very often. I have no idea about this error so can anyone help me to fix this ? I don’t have big experience working with Windows Server.
Thank you !
Event Properties-Event 1, kladminserver
The description for Event ID 1 from source fladminserver cannot be found. Either the component that raises this event is not installed on your local computer or the installation corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with event.
The following information was included with the event:
Administration Server stopped due to error.
#1950 (515) Generic db error: :515” Cannot insert the value Null into column “hostname”, ‘KAV.dbo.tsk_host_state’; column does not allow nulls. UPDATE fails.’LastStatement=EXE upgd_tsk_glb_ri_hosts’
