Cannot install Adobe flash player?
I use Mozilla Firefox.
I downloaded Adobe Flash player and tried to install it, but flash player does not install. I also tried using Mozilla Firefox and Opera, still my problem persists.
What can I do?
What can I do?
Hello Mr. Khaled_mithun,
I read your problem and  I think, this is not a very critical problem.
I will give you some workable solutions, for your problem. Please read the below solution and work them step by step and  I think your problem will be solved.
I think Adobe Flash Player may not be installed because of many reasons, such as:
•   It could be a shortcut file.
•   It could not be downloaded successfully.
•   You did not download, all files that are needed.
•   You were not able to complete installation successfully.
In that case, I suggest to that you follow the instruction which are given in that file or in the site, where you downloaded the software from. Â
You can also see an option ‘help’.  There are two kinds of help.  One is for downloading the file and other is for installation of the file.  You just need to follow this and you will able to install Adobe Flash Player.
Arafat hossain
