Cannot Install Adobe Suite Because Adobepdf Dll Required
While installing Adobe Suite 3 on my Windows 7 64-bit machine, I got the error the file adobepdf dll is needed and the installation program crashed. How do I proceed with the installation? Can I do it on my own?
Answered By 0 points N/A #322935
The error you are getting is a kind of DLL file error. These errors are common and can be resolved easily by any type of user. The adobepdf.dll is a DLL file associated with the Adobe Suite. Since your installation crashes after the error, you need to have the adobepdf.dll file on your computer before you start your installation.
Doing this is quite simple. What you need is to download the missing file from the internet and place it in the System folder on your computer. Restart the computer and then begin with the installation. The error message will no longer appear.
