Cannot install KeyShot 3.0.99 trial on Mac OSX 10.6.8
Hello everyone!
A couple of hours ago I downloaded the trial version of KeyShot 3 for Mac and ran the installation package. The installer gives information victory on the other hand however I attempt to run KeyShot, I receive an error message stating that I "Cannot execute the package because it's broken or incomplete".
After this I found “It depends on the organization that why I asked. In your case there shouldn't be any problems then. Try and change the permissions of the KeyShot3.app/Contents/MacOS folder from custom to read only.” I attempted to modify the authorization as recommended, does not look to make any dissimilarity entirely.
You can see the attached image to view the error message.
You can’t open the application Keyshot3
because it may be damaged or
incomplete.
