Lwans
Posted on - 07/20/2011
I downloaded ms office in this format .iso i.e Office 2010 ProffessionalPlus 32bit.iso (image file). When I double click it cannot unzip, it opens like an image. When I unzip using winRAR or 7-Zip and then try to install it, it brings back the following error "An error occurred during installation, and setup was unable to complete". How can I fix this without buying another Ms Office?
Katei94
CANNOT INSTALL MS OFFICE 2010
I think you do not want to unzip or unpack the iso image file using any compress software. All you have to do is to mount the image file using any mounting software and Microsoft office setup will automatically start. I recommend you to use DAEMON tools or Magic ISO for this purpose. If it does not autorun you have to browse the Image for the setup.exe.As you are trying to install a pirated copy make sure the internet connection is disabled. It may be ok to disable the antivirus software in installation process to avoid conflicts. Your system must pass the minimum system requirements for installation. If every attempt fails there might be an error in the ISO file and you need to look for another ISO from different websites.
Kirk25
5 points
Hello Lwans,
I think I can help you understand this problem.
Incompatibility problems. These are the required specification for 2010 from microsft.com. Your PC must meet these requirements. First , if you are running windows XP, but not service pack 3, error on installation could occur.Also, the version of Office 2010(64 bit) does not support Windows XP(whether SP2 or SP3), and Windows Server 2003.
Another cause is the installer itself, it could be corrupted.
Your extracting software is another possible cause, try downloading this software , its free , (https://iso.reactos.org/bootcd/bootcd-46893-dbg.7z) . Or if you have Nero, just burn it on CD/DVD then run the program or install it form here.
another good software for extracting ISO is Magic Disc – it is a software that allows you to create a virtual drive CD/DVD drive and read the ISO just as if it had been burned. Read help for instructions after downloading.
Always,
Kirk25
Hello Lwans,
Besides these solutions you can solve this issue by applying another techniques too. Pay a visit this Techyv page and get those smart and easy techniques.
Unable to install Microsoft Office 2010
