I have a problem, foiled with this error. Yesterday I try to download a star war game and the download was complete. Then the real problem rises, when I try installing I ended up with error. After this error the installation is stopped. How will I find error? What is the cause of error? Any file is missing in download? Help please.
Image of the Error:
Error Message in the Image:
Feature transfer error
Feature: DefaultFeature
Component: FameFolder
File: E:data2.cab
Error: Datavirhe (CRC-tarkistus)
Cannot install star war game
There are actually different kinds of Star Wars game that you can download on the web and this issue is best resolved depending on the game you are installing and also remember that not all Star Wars games have the same system specifications. If you verify that the download is one hundred percent complete then there should be no problem.
The bad news is you did not mention the exact name of the game you are installing so we can better check its compatibility over your computer. So since I don’t know what Star Wars game you are installing, it will help you if you will check the game’s system requirements from the website where you downloaded it.
In case your operating system is supported, try running it or I mean try running the installer as administrator. Since it is a download version, right-click on the installer usually with “setup.exe” in the filename and select Properties. Select Compatibility tab and check “Run this program as an administrator” located at the bottom under Privilege Level and then click OK.
Run the installer again and see if it works. If you are installing the latest online game Star Wars: The Old Republic, there should be no problem installing it on your computer. It works on Microsoft Windows XP Service Pack 3 and higher but requires a 2.0 GHz Core 2 Duo processor. Visit Star Wars: The Old Republic for more info.
