I cannot install on vista 64, what’s wrong? I got an error message, what’s the problem? An older TotalMediaExtreme Trial (with TotalMedia Theatre) worked fine before. I really need your help to fix this issue. Can you provide me the proper solution? Thanks.
Themida
Cannot find ‘HDNavigateCore.dll’. Please, re-install this
application
OK
Cannot install on vista 64 Themida what’s wrong?
Hi Richard,
You downloaded the application you want to install as corrupted or not completely. To be able to install the application to your computer download it again or make sure that this is compatible with your computer. All applications are found for the .DDL they needed so make sure that you meet the system requirement for all applications that you want to install and if that is not corrupted or you downloaded it completely.
