CS4 Creative Suite 4 has been installed. Whenever I try to launch Photoshop CS4 an error occurs: "Photoshop.exe Application Error. This error reference 0x6963561b and that memory cannot be read at 0x0000008c”. I cannot still use Photoshop. I get the same results even after I have already tried uninstalling and reinstalling the suite. Please, give me a solution to this problem
Cannot launch Photoshop CS4 files
Solution 1:
The problem produces because of video card.
You purchase a new 1gig video card after this problem will surely solve.
Video card is also called graphics card, display card, graphics adapter and graphics board. Video card is used to generate feed of output image to display. Compositing capabilities and 3D editing are offered by Adobe Photoshop CS4 these are used in the graphics processing unit. If you work on large image or complex image, video processing is necessary.
For further instructions see about OpenGL help on Adobe Photoshop CS4.
Solution 2:
Multiple video adapters can produce problem, so remove the additional cards.
