Aimee Heart
Posted on - 02/02/2012
I need some help with Alcohol virtual CD-ROM driver.
I recently upgraded to Windows XP Professional and every time I click on the Alcohol icon an error message pops-up saying that I cannot load the Alcohol virtual CD-ROM driver, and I have to re-install Alcohol 120% to correct this problem.
So I did and now I am getting the following message, ERROR 1606.
Could not access network location": Documents and Settings All User Desktop.
Can somebody tell me what’s this all about?
Cannot load Alcohol Virtual CD-ROM
Alcohol 120% system requirements:
Pentium or AMD processor
Windows 2000
Windows Server 2003 32-bit or 64-bit
Windows Server 2008 32-bit or 64-bit
Windows Server 2008 R2 32-bit or 64-bit
Windows XP Professional 32-bit or 64-bit
Windows Vista 32-bit or 64-bit
Windows 7 32-bit or 64-bit
32 MB RAM or more recommended
10 GB available hard disk space
One or more CD or DVD optical drives
I think you don’t have a compatibility problem. But just to make sure take a look at the list above and check your system if it complies with the above requirements. If all seems well and you still have problems running it, try uninstalling the application again then check your computer for any possible errors it might have. Use a disk utility application to diagnose your system. If you don’t have one installed on your computer, you may use Windows’ disk check tool.
Right-click drive C then select Properties.
Click Tools tab.
Click Check Now.
Check Automatically fix file system errors then click Start.
After checking your system, install Alcohol again. If you still get the same error again, maybe there’s a problem with your installer. Download Alcohol 120%.
For a much thorough diagnostics, use disk utility applications like Norton SystemWorks or Norton Utilities 15.0 instead of using Windows’ disk check.
