Hi there,
For two days I have this error message and I don’t know how to fix it. It appears every time my PC logs on. I don’t remember installinguninstalling anything lately so is a little bit weird for me to have this error. Does anyone know what is happening with my PC and how can I fix this error?
Thanks!
FineObjects
Cannot load unicows.dll. Press Cancel to terminate application.
OK Cancel
Cannot load unicows.dll Press Cancel to terminate application
Generally unicows.dll error occur at the time of installing certain programs, when Windows starts or shuts down, or even during installation of windows. These error may occur due to mishandle or corruption of the unicows DLL file or a registry problem or malware function or may be a hardware failure or an incomplete software installation. Do not try to download unicows.dll from a ‘DLL download’ website. It is good to obtain it from its original, legitimate source.
Here is how to solve Unicows.dll errors:-
If you’ unable to access Windows normally due to the unicows.dll error the start windows in safe mode.
If you by mistake deleted this file then recover unicows.dll from the Recycle Bin.
Sometimes some unicows.dll errors may be related to virus or other malware infection on your computer that may damage the dll files. So scan and fix Windows Registry.
Download and replace unicows.dll manually to fix the error.
points
There are many ways that your PC’s DLL files might become corrupted. In order to fix this issue, you have to install a new piece of the DLL file or re-install the application.
1. Download unicows.dll.
2. Copy the DLL file inside “%SystemRoot%System32”.
3. Start Command Prompt with administrator privilege. Then, execute this line:
regsvr32 unicows.dll
4. Restart your PC.
I’m sure that the error won’t bother you anymore.
You should also check your PC for viruses because the virus might even corrupt the new DLL file. Use any good antivirus, for example, Norton, Kaspersky etc.
