aldiaz
10 points
Posted on - 04/07/2012
Hi guys.
I was searching on the web for a music downloader.
After downloading the file, I cannot locate it on the Download folder.
Is the destination wrong or is it automatically set into a hidden file?
I would really need your help.
Cannot Locate my Downloaded Files
Hi dear,
If you can't find it on the Download folder , it may be saved in another folder which some how was set by you before the time of another download from web. There is a way to find the location of your downloaded soft were .
Go to start menu and then to search
Then click on Files and Folder .Then a window will open as like the picture below –
Then click on All files and folder.Then another window will open like as below –
Then write the name of your software and in Type of file option click on All files and folder .Then click on search.
If your suggested soft were has saved anywhere in your computer it will shown on the page after searching as above picture. You can find also the folder name in which your software was saved .
I hope this solution solve your problem .
