Cannot Login To My Gallery Remote Application
I have set up Gallery Remote 1.0 on my Windows XP system. Attempting to join to the web page where I can set up gallery, applying my standard FTP username and password, however unlucky: sign in fault: password inappropriate.
Well, I have inspected it, twice examined, and multi looked at the username and password are accurately similar as my web hosting service records FTP username and password. The gallery link seems tad like this: https://www.mydomain.com/gallery.
What do you think is the problem? I know my username and password is correct.
Thanks you for your feedback.
