Cannot login to my MS Outlook client because of MS Exchange
Hello.
Because of Microsoft Exchange, I can’t log on to my regular account using Outlook 2007. MS Outlook 2007 prompts that I have to be logged on to MS Exchange before I can proceed. I also get this error message:
"MS Exchange is unavailable and that Outlook can’t log on; please verify if you are connected to a network."
If this information helps, I am using Windows Vista and Gmail is my default mail.Â
How can I remove this problem? And I also want to remove my MS Exchange account. Yet when I do so, the system says that I cannot delete the MS Exchange account, and that the configuration data is copied to various applications. Please give a solution. Thanks a lot.
