Leishalynn
Posted on - 11/20/2011
May I ask what an Adobe Reader application is? How could I apply Adobe Reader and maximize its service’s advantage in Acrobat.com? Also how will I download the Adobe Reader without the Adobe AIR? What necessary steps should be done if there is an error in Adobe Reader? Prompt message like “CANNOT OPEN EBX TRANSFER FILE” pops up. What’s the reason I get an error after installing Adobe Reader in my computer?
Hi friend,
Adobe Reader application is software which is used to open e-book that means .pdf files. In other words Adobe Reader means .pdf reader. You can edit and save pdf file with it.
From Acrobat.com you can update your current Adobe Reader application version and add more feature on it.
You can not download the Adobe Reader without the Adobe AIR. For new versions this is a built in function for adobe reader. But you can install adobe reader without Adobe AIR.
If there is an error in Adobe Reader you can uninstall and reinstall it or update it with new version.
After installing Adobe Reader that error shows because your computer is not connected with internet for that moment. Just ignore it.
