I have this Holdem Manager installed in my system. As I was inputting some number when suddenly this error occurred. What is the quick fix for this? Do I need to reinstall the software on my personal computer?
Table manager
Can’t open file C:Program Files (x86)RVG SoftwareHoldem ManagerLibrary.dll
Cannot open Holdem Manager Library
Hello Dominic D Beaton,
This error shows when one of the files of Holdem Manager corrupted or cleaned by antivirus. Try to copy the Library.dll file from the Holdem Manager Installation. Alternatively, you reinstall the Holdem Manager again and solve the problem. Please make sure your Antivirus turns off.
Hope it will help you.
Hi Dominic D Beaton,
Good day!
Your antivirus seemed to be suspicious about that library.dll file that causes the corruption of the software. If you want to check if it isolates the file, right click on the antivirus that you have and check its overview by choosing open and clicking it. An overview of your computer's health will display on the screen and choose the vault on which it Your antivirus seemed to be suspicious about that library.dll file that causes the corruption of the software. If you want to check if it isolates the file, right click on the antivirus that you have and check its overview by choosing open and clicking it.
An overview of your computer's health will display on the screen and choose the vault on which it sticks up all the viruses that it seems to be suspicious, locate the one's that has the library.dll file on the end of the file location and then click the file once and restore it on the file then try the program again.
