Cannot Open Microsoft Outlook After Upgrade
Help, Techyv!
I have just upgraded my Microsoft Outlook 2003 to 2007, and now when I try to open it up I get the following error message:
Microsoft Office Outlook
Help, Techyv!
In case you face a situation like this you do all my solution that Iisted below:
Remove the extend.dat:
Windows XP:
1. Click Start and then Search. the All Files and Folder and the More Advanced Options. Look for the Search hidden files and folders. Check the check box on it.
2. Then on the search text box type extend.dat then Search.
Windows VIsta:
1. Click Start and type in the search box the extend.dat and then click the search icon.
2. Advanced Search, and the Include non-indexed, hidden and system files check box then on its right type the file again then click Search.
Notifications
