Cannot open my newly built computer.
I just recently built a computer but I am having a problem with it, when I connect it to the monitor nothing shows up, I double checked everything, and everything is brand new, but I don't know what's causing this I think its the processor but its brand new.
So what can I do at this moment?
Best Answer by Allan Mill
Answered By 0 points N/A #113701
Make contact with the seller From Where you Have Delivered This System. This will let you Reimbursement, While you Pointed out It Brand new Therefore You don't need to Fix This One. My Suggestion For you Is Look for a Great Personal computer Technician Which Custom made Develops This stuff. That is What I Would.
The cost Has been A lot less than Getting This From A favorite Business. It works Excellent. You can Pay Minimal Bucks In for The computer Excluding Monitor, Loudspeakers, Or Printer's. It truly May run Any Computer software Available today As well as was created to End up being UPGRADABLE. Also you described Video games. It's going to Operate Anything at all you will find On the market today. Make contact with the seller From Where you Have Delivered This System.
This will let you Reimbursement, While you Pointed out It Brand new Therefore You don't need to Fix This One. My Suggestion For you Is Look for a Great Personal computer Technician Which Custom made Develops This stuff. That is What I Would. The cost Has been A lot less than Getting This From A favorite Business. It works Excellent.
