When I booted up my windows 7 computer this morning everything seemed to be normal.
When I attempted to open my Microsoft Outlook 2007 program to check if I received any new email I got an error saying this:
Error:
Microsoft Office Outlook
Cannot start Microsoft Office Outlook. Cannot open the Outlook windows.
I clicked ok and thought to myself that maybe I shouldn’t have skipped the scan during boot up.
When I restarted my computer and tried again I still got the same error.
Help me fix this please!
shenna22
5 points
Cannot open the Outlook Window
Hi good day you know I encountered this kind of problem during I open Microsoft outlook.
And some of this file being missing or corrupted. To repair the corrupt file.
Get your Microsoft office CD installer and put it into the CD room.
Then the setup of the Microsoft office will be flash in your screen. Find and select repair.
In these steps the corrupted file will be restored.
Open the Microsoft outlook, and it will be ok.
Thank you and have a nice day.
Hhope you can do it.
God will be Bless you
Regards;
Shenna22
usher
Try to uninstall it and then restart your system and then re install it and then check it again after restarting your system.
Or you can try to repair the corrupt files by inserting the windows CD and repair all files instead of installing all the windows.
It will automatically find the missing and corrupt files and repair it; otherwise you can also try this method to fix the problem
Go to Start > Run > type outlook.exe/resetnavpane and click the Ok.
You can use the following steps.
Open control panel and change the window into classic mode and view profile by double clicking on the mail.
If you see any other profile other than General then changes the settings to default.
And check it again.
Hello Bruce
Besides these solutions there are many way you can apply. There is a Techyv post where you will get some new techniques to solve this issue.
I Cannot start Microsoft Office Outlook.
