Cannot open word format file in bryggnet
I just tried to open a file that was saved in Microsoft Word format but I can’t access it properly and experience the following error message. I have tried all the queries to resolve this matter but I remained unable to solve this error. To help me out of this problem. Thanks.
Cannot open bryggnet
The filename “bryggnet” indicates that this file is of type “Unknown type”. The contents of the file indicate that the file is of type “Folder”. If you open this, the file might present a security risk to your system.
Do not open the file unless you created the file yourself, or received the file from a trusted source. To open the file, rename the file to the correct extension for “Folder”, then open the file normally. Alternatively, use the Open With menu to choose a specific application for the file.
