As I continue with my missions and quests, placing a C.A.M.P. is a necessity. But how come I receive “Cannot place item: Furniture entry is blocked” when I try to tie my C.A.M.P.? I’ve done this before, I mean putting up a C.A.M.P. in one place but this time I can’t. How do you fix this?
Cannot Place Item: Furniture Entry Is Blocked – Fallout 76
In Fallout 76, when you receive this message “Cannot place item: Furniture entry is blocked”, it indicates that one of the furnishings in your house or C.A.M.P. is in a position where something else is overlapping it. When one item is overlapping another, this would prevent the placement. You won’t be able to place the item and you won’t be able to use it.
At the moment, the only way to fix it is to cancel the placement of your C.A.M.P. and break the Blueprint into pieces. To break the Blueprint into pieces, go to the “Stored” menu then select the Blueprint. Next, press the button to “Store the Blueprint”. You will then be prompted with “Delete blueprint and store all component objects?”
By selecting this option, all items from the blueprint will be placed into your “Stored” tab individually. You will then be able to place the pieces back down without spending all the materials again.
