I am using the Duneflashinterface but it has a problem such that when I go to an existing series and then see if there are new episodes, I find the episodes and adds then but now I can’t quit. If I click close, I get the error in the image below.
Error message:
Absolute Engine Error # -4 Error updating record – record was modified by other process.
Cannot quit Duneflash interface program
I’m trying to find the system requirements for Dune Flash Interface but there was none available. So I think, since they didn’t provide any information about the system specifications of the program, we can assume that it will run on any operating system. There is a user who tried to create a language file set in German but encountered a problem because the preview button doesn’t work.
To fix this problem, the developer advised to install Flash Player ActiveX. So this means that for Dune Flash Interface to work efficiently, you need to install Adobe Flash Player ActiveX. Click Adobe Flash Player ActiveX latest version to download the latest version. This link will not open another site and will go directly to the installer and download it.
See if installing Adobe Flash Player ActiveX fixes the problem. If not, try upgrading your program to the latest version, Dune Flash Interface 2 [2.1.7]. If you are using Dune Flash Interface 1.5.6, download the ZIP file from Dune Flash Interface bug fixes. This will fix all the problems you encounter in Dune Flash Interface 1.5.6.
To use it, just unpack the ZIP file and replace the files. Remember, it will only work on Dune Flash Interface 1.5.6.
