Cannot rebuild Lotus database with DXL files
When I try to run the DXL files created by the Lotus Notes Recovery, there is no error message and it does not rebuild the database. I would like to know why this is happening and how to resolve this issue.
Answered By 5 points N/A #119912
You may not be using the wrong procedure and that is why the dxl files are not able to rebuild the lotus notes database. For you to be able to convert the dxl files into a new file, you will be required to run the batch file called runme.cmd. When you run that file, it will be placed in the same folder as .dxl files. That process will create the database automatically from scratch.
Once you have done that, you will need to should submit a valid path to notes.exe file, and you will need to ensure that there are spaces included in the batch file. In the event that there are error messages that appear during processing of batch file and a new file ceases to be created, you will need to reinstall Lotus Notes
-Experttechyv
