Cannot record audio from any application using Camtasia Studio
I am using Camtasia Studio on my Windows 7 PC; the problem is I am unable to record any sound from applications such as sound from a game or video clips.
The volume controls are grayed out.
How do I fix it?
What are the things to remember before recording an audio?
Your help will be appreciated.
Thank you.
Answered By 0 points N/A #115012
Hi friend.
I will teach you just follow this.
First step:
Enable the Audio option.
Second step:
Click the Audio dropdown to select the audio source.
Third step:
Adjust the Input Level  so the highest volume displays in the green to yellow range. Audio clipping may occur in the mid-orange to red range.
Fourth step:
Click Ok.
Your can record audio at a later time with the Voice Narration option  in Camtasia Studio.
AUDIO SOURCE THAN YOU CAN RECORD:
– Microphone
– Speaker Audio(what you Hear)
– Line In
If your problem will not be solve in the instructions stated above follow this:
When the audio level doesn't change when the audio is present:
Verify that the audio input source selected is connected and turned on.Verify that the correct audio input source is selected.
To verify;  Click the audio dropdown and select options.Verify that the volume slider is not muted.
If the audio level is low. drag the slider to the right.
Audio Level is in the orange to red range where clipping can occur. Drag the slider to the left.
Hope it can help you..
