Yuan Hayden
10 points
Posted on - 06/06/2019
I receive “Cannot remove item: Part of the structure would not be accessible” in Fallout 76. I receive this message when I tried to remove an item from my C.A.M.P. I don’t have this problem before and I just keep adding items or putting items to my C.A.M.P.
But one day, I think I reached the maximum load of my C.A.M.P., I can no longer put anymore items. That’s when I decided to remove items from my C.A.M.P. But the problem is I cannot.
Cannot Remove Item: Part Of The Structure Would Not Be Accessible – Fallout 76
When you receive “Cannot remove item: Part of the structure would not be accessible” when you try to remove an item or items from your C.A.M.P., it means there is an item or items placed in your C.A.M.P. that is dependent on the item you are trying to remove. The game will not allow you to do this without removing first the dependent item.
Like for example, a door placed on a wall will prevent you from removing that wall without first removing the door. To fix the problem, see the item you are removing and check what other item or items are dependent on that item. Once you located the dependent item or items, remove it first then once the item is removed, remove the item you want to remove.
