scottnolans
Posted on - 02/21/2012
Hi experts.
I am using Windows 7 OS on my computer. I tried to install Clam AntiVirus 0.96.5, but now I can't renew my database. I am getting the following error message:
ClamAV update process started at Tue Jan 04 11:59:06 2011Â
Downloading main-53.cdiff [100%]Â
WARNING: [LibClamAV] cli_loadinfo: Incorrect digital signatureÂ
WARNING: [LibClamAV] cli_loadinfo: Problem parsing database at line 8Â
WARNING: [LibClamAV] Can't load main.info: Malformed databaseÂ
WARNING: [LibClamAV] cli_tgzload: Can't load main.info
WARNING: [LibClamAV] Can't load C:UsersMick JaggerAppDataRoaming.clamwindbclamav-6e67108dae1db2116ca98c08e868af37.0000076c.clamtmpclamav-2c6582d949b3eb378709d6d46a0910d9.0000076c.cla.cld: Malformed databaseÂ
ERROR: Failed to load new database: Malformed databaseÂ
ERROR: Failed to load new database: No viruses detectedÂ
Please help me to solve this error. Thanks in advance.
Cannot renew database while installing Clam AntiVirus 0.96.5
Hi
The problem is that your database is not renewing and not uploading through the anti-virus installation this is the fact that you have to check and install software which will help you getting rid of this problem. The antivirus you are using is not compatible with your database and he is not willing to upload that database so you should have to try and replace the anti-virus because there is some anti-virus which detect the database as virus due to this factor your anti-virus has not been installing properly. And your database is not working properly. So replace the ant-virus
Hope this solution is helpful for you.
