I download the trial of the game "Angry Bird Rio".
After the installation I cannot run the game. Even the trial.
It gives me a error message.
I have attached a photo. Please view this and you will understand my problem clearly.
Thank you from.
Mynameismishuk
Error
OpenGL 2.0 renderer not supported! Reason:
OpenGL 2.0 is not supported
OpenGL 1.4 renderer not supported! Reason:
OpenGL 1.3 is not supported
OK
lee hung
75 points
Cannot run the game “Angry Bird Rio”
Hello Myna,
It seems you have downloaded a game that is intended for a different operating system and therefore cannot work on the operating system that you are using. From the image that you have attached, it is most probable that the game is meant to be installed on either a Linux operating system or a mac operating system, and you may be trying to install it on windows.
I will therefore suggest that you Google for the right game for the operating system that you are using and them download. When searching, ensure that you include the system specifications of your computer to get the right game for it, and then install and see that the response is.
__
Regards
Lee Hung
