Cannot run Windows on SONY PCG FX140
I bought an old SONY PCG FX140 and I can't run windows on it. The blue windows background with the windows logo appears but then the error ''scandisk has caused an error in msvcrt.dll scandisk will now close If you continue to experience problems, try restarting your computer''. When you close that, it says "rundll32 has caused a problem in msvcrt.dll", then ssdpsrv, then spool 32, then stimon, then statemgr, then scrolling mark, then it starts with scandisk again.
I rebooted the process like twice before running windows
I used recovery disk and restarted it a several number of times. I need my windows to load for some important information. I hope someone can help me with this problem. Thank you for reading this and I hope you can give me solutions.
