Cannot save Adobe Photoshop’s page.
I am editing a picture and I want to save that page using options, save or save as.
But then I face a problem. It does not save or save page as.
How can I save or save as that page?
Hello, If the image will not save, then there must be something wrong while you are saving your image file. Try Following these simple steps:
Just select the file command above your screen, then you will see a drop down menu, you will then see options in saving your file. If the image has a file name, just click save but if you need to create a file name or the file doesn’t have a file name yet, just click the save as button, saving options will then pop-up.Â
Now just put a file name in filename bar, then below is an option as to what format the image file would be saved. Options are JPEG, TIFF,PNG or PSD. You can just select JPEG then select a path, what drive your image will be; save. Then Ok.
That’s it…Hope this will help.
