Cannot save as in Photoshop CS5
Would ask for members who use Photoshop cs5 Techyv mainly install it on a notebook.
I recently installed Photoshop CS5, the problems that I encountered that every click save as save as its window does not appear.
There is a solution for this problem?
I use the HP Mini 110-3001TU
specification
OS Windows 7
Processor Intel Atom CPU N475 1.83 GHz
Ram 1 GB
VGA Intel Graphics Media Accelerator 3150
Best Answer by Rennier Lean
Answered By 0 points N/A #115226
Hi, the save as button in your adobe photo shop is not working due to the minimum resolution of 1024×768 requirement, as far as I know notebook resolution is just limited to 1024×600, that is why once you clicked the save as button no dialog box will appear. Follow these steps:
Enter: WINKEY + R
TYPE: REGEDIT
In registry enter to search then CRTL F
Type in the search dialog: DISPLAY1_DOWNSCALINGSUPPORTED
Select and change their values from 0 to 1
Close then restart
Once done, this will allows to change the display settings on your screen and allow the dialog window to appear, the solution is due because of a reduced standard in CS5.
Answered By 0 points N/A #115228
Again my laptop not support for this software because notebook resolution 🙁 . Thanks a lot  Rennier Lean
