Cannot scan properly of my Scanner.
My scanner is cannon. I setup this scanner properly. But when I scan any paper then I got ugly result. It was very light. I search all program of scanner. But I do not found any problem. So what can i do for this moment.
Best Answer by ganyliss
Answered By 5 points N/A #116711
Hi dear,
You can get the better choice from here, how can you use your scanner for scanning properly. I would like to explain it in a brief passage. The type of scanner like flatbed scanner is working same like the photocopy machine. For getting more output you should use a software for operating the scanner. Most  of the  image editor programs have a menu like this,  File-Acquire or File-Scanner are used for scanning the image, there is also a toolbar scanner sometime too. TWAIN driver is used for this software. It is also acronym for the technology without any interesting name of it. This driver is provided by the scanner manufacturer. It has also some controls those which we specify for scan. For more information……….                               https://www.scantips.com/begin.html
Answered By 0 points N/A #116712
Your scanner might not have enough power when processing. Try to connect your scanner power directly on Automatic Voltage Regulator (AVR) so that enough power may come in.
The worst is when your scanner problem is the scanning bulb. This may cause a light and a blurred output in the paper. If the problem is this, you may change the scanning bulb by replacing it manually.
You can adjust the brightness or colors of your scanned image using Photoshop tools.  But as far as the hardware is concern, try to call for help. Find a nearest computer expert in your area and let him fix your machine or the scanner.
