I am having some problem with MS Word and I need some assistance. I have a word file with a circuit which is seen in other computers but I cannot see it in my office 2007. I have tried different equation settings but none of them worked. So please help me get rid of them problem so that I can work properly.
Dixon Chapman
Cannot see circuits on Microsoft word 2007
Dear,
I have a solution for you. This will resolve the problem completely.
If you want to draw the circuit you have to follow these steps and they will be shown as well easily. I am sure you are missing some step that’s why you are unable to see these circuits. Please check out the step and make circuit again.
In Word 2007 click on the "Insert" tab then click on the "Shapes" button. This will pull down a drop down with multiple shapes, lines, etc. You could also choose the "New Drawing Canvas" option at the bottom of the drop down to create a new drawing space which should give you access to the "drawing" context tab on the ribbon.
Hope so you got the point.
