I own a laptop and I need to know it's different features including its graphics properties. I do not know how to see the graphics properties and I can see an NVIDIA device installed which I have known to be a graphics device. So please someone give me suggestions about how to see the graphics properties.
LIoyd Cooper
Cannot see the graphics properties on my laptop
Hey Lloyd,
If you are not showing you graphics properties. Make sure that your Graphics drivers are correctly installed. There is a possibility that your drivers are out of date or incompatible. You can use some software like Driver genius to auto download the latest drivers and you can also download it manually.
Once installed the drivers you can right click on the desktop and click on the Graphics properties to view them. Secondly you can also view a small icon on system tray, beside your system time, click on it to view the properties. You can also open Run Dialog box by pressing Windows+R, and type DxDiag to view your graphic card drivers and properties.
Hi there,Â
I have a perfect solution for your problem. The best way to find the graphics, motherboard, processor and other details are through the directx diagnostic tool or the dxdiag tool.
To open it follow my steps:-Â
1. Go to run by clicking start or for shortcut press win key +Â r.
2. In the window that appears type dxdiag and press enter.
3. When it prompts click yes and then a box appears in that click the display tab above.
4. There you can see all the details.
Hope that solves your problem and is clear to me.
Thank you very much Lesten Pasio,
It was very easy because of your instruction. I run cmd and type dxdiag. Then, chose the tab Display. And I can see every detail of my graphic drivers.
Thank you very much!
