I have some hidden files in my hard disk which I cannot find or see. Unfortunately I do not know how to make the hidden files visible. I will be grateful if someone teach me how to make hidden files highlighted. I have lots of space covered by these hidden files.
Spencer Reynoso
Cannot see hidden files-how to make hidden visible
For you to see the hidden folders on your system please follow the steps that I will give you. First is click on run and then click on control panel and the control panel window will open you need to search for a folder options icon (you must view them by large icons or small icons) Open the icon and then a it will open another windows and you will see a view tab on it click the view and there you will see "hidden files and folder" you need to click on "Show hidden files, folders and drives" and then click apply and then ok and then you will see your hidden folders
