Gifford
200 points
Posted on - 05/30/2011
I have successfully installed Pinnacle LINX2 Audio into my PC and after the Windows had detected the hardware, I got this error message “This device cannot start. (Code 10)” I restarted my PC thinking that I need to do this method so that my PC will be refreshed and to recognize it, but afterwards the same error had appeared.
I consulted a friend about my concern and he told me to uninstall the driver and install it again. I did as what my friend had suggested but it seems that nothing good had happened. Please help me on how will I address this problem.
Thanks a lot for your help.
Karlos
Error 10: The Device Cannot Start Pinnacle LINX2
Hey
There are possible reasons why that error is happening to you either the installed driver is bad, something is missing in the driver installation or the driver is not compatible with your system. What I can advise for you to do is go to the manufacturer's site of your device and get the latest driver for it for your system. You can also do this by updating the driver in your Device manager:
Got to your My Computer and right click, choose Manage and go to Device Manager
Find your device and choose Update Driver.
Make sure to connect it to the internet to get the latest driver.
Hope that helps.
Jacob077
Mostly this error occurs due to drivers faults. However the device is recognized through the drivers, they are not compatible with the hardware component. Go to the original web site of the device and download latest driver for the device. And uninstall the existing drivers and install the downloaded drivers.
