Halton Roy
50 points
Posted on - 08/20/2012
Hello, I have successfully installed LoadUI on my PC. But the problem is when I try to open it I get a n error message. I have never been able to start this program. please let me know how can I start the program. Below I am giving the error message….
Error message : Unable to launch the application.
Publisher: eviware
Cannot start LoadUI on my PC.
You need to install tool which has java version machine that compatible to the windows that you are using. For example, if you are using windows 32-bit then install 32 java version machine, and then if you use 64 bit windows then install 64 java version machine. If you installed load ui in computer which has 32-bit java machine then configure the load ui to load as 32-bit by editing the configuration in load iu bat file, then also if installed on computer which has 32-bit java machine then configure it also in load iu bat file. So the main idea here is the compatibility issue on windows that you are using.
Hope this helped you.
