Cannot start video compression VirtualDub Error
In order to easily watch a movie over the web, I usually compress the size of a video file. I have Windows Movie maker installed on windows XP machine for the same.
I perform the following action on a Video file and get an error message. I open the program, Click on Import Video, later I select the file, drag it down to the location and then when I click on save action, a dialog box pop’s up.
Hope the above information helps you to find a solution for my error.
VirtualDub Error Cannot start video compression: The source image format is not acceptable. (error code -2)
VirtualDub Error
(error code -2)
Best Answer by AngusM
Answered By 0 points N/A #115056
Hi Shawn Campbell,
Can you provide some info on what file you were trying to compress when the error showed up?
"Cannot start video compression: The source image format is not acceptable. (error code -2)" indicates that the format of the video you are trying to process with VirtualDub is unsupported. For starters, please download and install the latest VirtualDub from here:
(https://sourceforge.net/projects/virtualdub/?source=dlp)
Another, more practical suggestion I can give is to switch to other user-friendly video conversion apps such as:
Freemake Video Converter, SUPER, iWisoft Free Video Converter, or Format Factory.
The above applications are all excellent choices, are more user-friendly than Virtualdub and are totally free.
Hope this helps!
Answered By 0 points N/A #196466
I encountered the same error on Windows 98. I was finally able to figure out that I was setting up Xvid and was never actually choosing the stats file which was trying to use an incomplete one.
I was not used to the new GUI of the codec. It puts the stats file settings under advanced options but not up front where they used to be.
I hope this information is helpful.
