TracyJohnson 0 points N/APosted on - 09/08/2011
Today I have decided to install and play WoW game, but I have met some difficulties. Game installation completed without a problem, but when I try to launch it, the error is shown. After pressing OK button, the game doesn't load. I think it may be due to my computer is too slow for this game?
It looks like that there are some errors in your installations. So the first thing you should do is that re-installs World of Warcraft. Even if that doesn't help then make sure that your graphic card drivers and Direct X is up to date and your system meets the minimum game requirements. I hope you find the solution.
If you installed “World of Warcraft” but it doesn’t start and gives you that error instead, check the system requirements again and make sure your computer meets those requirements. World of Warcraft supports 64-bit Windows 7, Windows 8.x, and Windows 10.
World of Warcraft
It requires Intel Core i5-760 or equivalent AMD FX-8100 or faster processor; 4 GB RAM; NVIDIA GeForce GTX 560, AMD Radeon HD 7850, Intel HD Graphics 530, or better video card with 2 GB video RAM; 70 GB free space; 1024 x 768 minimum screen resolution; mouse and keyboard; and broadband internet connection.
If you verify that everything is fine, try disabling your antivirus or firewall temporarily before starting the game. If this doesn’t work, try running the program as admin. Right-click the game launcher then select “Run as administrator”. If this works, set the client to always run as administrator. Right-click the game launcher and select “Properties”. On the “Properties” window, go to “Compatibility” tab.
Under “Privilege Level” section at the bottom, check “Run this program as an administrator” then click “OK”.
1....
